Ip dimmer blows .
I'm thinking there is a short to ground somewhere. I have no clue where to look though. Help!
1. Pull off trim ring around gauges.
2. Take out your dimmer switch
3. Take a screwdriver and pop off the little metal clips on the sides of the switch. This will let you open it up and look at the circuit board. If the board is broken, that will make your fuses pop like corn.
