Sponsored by: CARiD
o2 sensors
Old Apr 14, 2012 | 10:30 PM
Jr.Samples's Avatar
Default o2 sensors
I was going to replace the front o2 sensors until I realized the front ones have a flat 4 pin connector while the ones (I have) after the cat are the square 4 pin. I was told they all were the same. I am not going to splice the old flat connectors on so where should I go to get the correct ones for this? Is this even correct?
Thanks.
Old Apr 14, 2012 | 11:56 PM
sargez28's Avatar
What vehicle is this on? I have a 2002 Z28 and all of mine are square connectors.
Old Apr 15, 2012 | 12:03 AM
bigbomber5's Avatar
Make sure the previous owner "did not" use extensions on his wires ( especially if your car has headers). If you have headers then hopefully you bought Vette O2's that have wires longer than 18"....
Old Apr 15, 2012 | 08:09 AM
Jr.Samples's Avatar
97 LT1 Formula. No headers, The drivers flat connector is somehow fastened to the toeboard/firewall. It's a little hard to see. So I understand all four of these should be square connectors?
Old Apr 15, 2012 | 08:34 AM
eseibel67's Avatar
LT1 uses flat connector on upstream O2's, sqaure on rear.
LS1 are all square.
Old Apr 15, 2012 | 01:37 PM
Jr.Samples's Avatar
Thanks
Where can I get the flat ones?
