Sponsored by: CARiD
Bad Misfire issues, Please help!
Old Apr 27, 2012 | 08:53 PM
mike.warrenws6's Avatar
Default Bad Misfire issues, Please help!
ok so the other day i started having constant misfires, and they after they got realllly bad and are still horrible... i have a 99 T/A Ls1
I put in NGK TR-55, New 10.2MM RPM Speed wires. Never heard of these before so i dont know how good they are but they dont fit on the plug itself very well... Made sure they were all gapped about a month ago. I made sure all the wires are properly connected, re checked the spark plug gap. i have the exhaust off and dumping around the middle of the car. idk if that culd be an issue
I was watching the misfires live feed on this scanner and it was only cylinder 2 and 7. 7 was the worse. i swapped around coils to see if it was coils but it was still 2, and 7. i got a couple misfires today also on cylinder 6 and one misfire on 8 but 7 and 2 are still the main ones, is there any other recommendations? an its weird. sumthing has to be up. when i first start driving off a green light it mis fires real bad and thru second and when i stomp on it u can feel it chug and pop as its accelerating hard, but then sometimes it all just completely goes away and drives soooo smooth. then happens agai nonce i finish driving and turn off the car.. i wonder if the wires i got are **** or sumthing?
Old Apr 28, 2012 | 04:59 AM
hotjohnnyls1's Avatar
did u hear the wires snap on to the plugs? n no thrown codes?
Old Apr 28, 2012 | 07:03 AM
bigbomber5's Avatar
Don't rule out bad plugs. I just changed my plugs/wires and I was getting a misfire on 6. Long story short, it was a bad new plug...
Old Apr 28, 2012 | 07:18 AM
elmarro's Avatar
If you still have 02's sensors try that cause it happened to me I changed plugs,wires,coils,I checked the mass air don't work well finally found the problem 1 of my o2's was bad ! What I did was I unpluged them and it was good after that so I changed the bad one its doing good since..
