Sponsored by: CARiD
Window regulator????
Old Jun 2, 2012 | 11:32 PM
MIDNITE Z's Avatar
Question Window regulator????
How do I install window regulator to get the bolts lined up.Once the tab is in I cant get the holes lined up. The tracks and wheels are all together.
Old Jun 3, 2012 | 09:51 AM
wssix99's Avatar
Save the manuals!
Eventually, it will rotate in to the right place as long as you have the hanger in the right hole - which you do. If you manipulate the arm that comes off the regulator rack, (not the one that has to rollers on it and pivots) you should have more precise control.
BTW - You don't want to use bolts here. You really need the special rivets sold by GM for this purpose. Bolts will lead to this problem - https://ls1tech.com/forums/general-m...-included.html
Old Jun 3, 2012 | 03:51 PM
MIDNITE Z's Avatar
Thanks man
Old Jun 3, 2012 | 07:21 PM
wssix99's Avatar
Save the manuals!
Oh - Another tip. If you line up just one hole and put a rivet/bolt in it to hold that one hole in place, its a lot easier to rotate the rest of the holes in to place.
Old Jun 3, 2012 | 07:25 PM
MIDNITE Z's Avatar
My next question......Where do the regulator teeth line up on the motor when you install it?
Old Jun 4, 2012 | 10:52 AM
wssix99's Avatar
Save the manuals!
The gear shaft on the motor lines up with the hole in the regulator plate and then you rotate the motor until the mounting holes line up.
Old Jun 11, 2012 | 12:12 AM
MIDNITE Z's Avatar
Every time I close the door the spring falls off......is there a clip that holds the spring in place? Here is what it looks like
By Brett Foote | 2026-06-04 05:00:17
