Sponsored by: CARiD
Hard to start and tach not working
Old Jun 13, 2012 | 06:09 PM
blacko2ws6's Avatar
Default Hard to start and tach not working
i replaced the flywheel, clutch, and pressure plate and it all works great except when i try to start the car it will turn over just fine but will take about 7 seconds or so to actually start. along with this the tach stopped working. i check all of my connections into the transmission and they are all good. any help??
Old Jun 13, 2012 | 06:15 PM
lt1pwr1's Avatar
Check your Cam sensor- you probably broke the sensor, or wires going to it, or burned them, etc.
Old Jun 13, 2012 | 06:27 PM
hotrodth's Avatar
Crank sensor...or cam sensor. Good luck. Both parts are approx 50.00 each
Old Jun 15, 2012 | 03:06 PM
blacko2ws6's Avatar
thanks, i read the codes and it was indeed the cam sensor, where is it located on these cars?
Old Jun 16, 2012 | 07:15 AM
w06gto's Avatar
Behind the intake manifold, you need to take it off to replace the sensor.
