Sponsored by: CARiD
Transmission Mount Twist
Old Jun 18, 2012 | 02:12 PM
RedVertTA's Avatar
Default Transmission Mount Twist
Title says it. After replacing my transmission mount with a factory style replacement and torquing it down I noticed some twist in the rubber mount, as it the bottom section is trying to twist clockwise. See pics below:
The mount was bolted to the tail shaft and torqued to spec at 18 ft lbs and the other end of the mount was bolted to the x member and torqued to spec at 77 ft lbs.
Is this normal?
Old Jun 19, 2012 | 04:38 PM
nomasterase's Avatar
what condition are your motor mounts in? maybe theyre worn enough to allow the engine and trans to be twisted enough to cause that
Old Jun 21, 2012 | 08:47 AM
RedVertTA's Avatar
They are new, so is the transmission mount.
Old Jun 21, 2012 | 09:06 AM
mjs1012's Avatar
If the motor mounts are poly you could have put one in upside down. I had the same exact issue and had to flip it over.
Old Jun 21, 2012 | 09:43 PM
RedVertTA's Avatar
Its not a poly mount, its rubber.
Old Jun 23, 2012 | 05:17 PM
99Bluz28's Avatar
It does that a little even with poly trans mounts. You could use a small pry-bar to hold it in place when you tighten it down.
Old Jun 24, 2012 | 09:48 PM
RedVertTA's Avatar
Will the twist actually hurt anything though? Or is it ok to leave it the way it is?
Old Jun 25, 2012 | 11:13 AM
mjs1012's Avatar
It might cause the tranny mount to rip prematurely due to the stress of it not being centered and forced into place.
