"Servo" motor for speedometer?
and after having the car looked at it was determined that the servo-motor for the speedometer in the gauge cluster is bad. I tried searching on google, ebay, and ls1tech for this so called servo motor for my car and came up with nothing, I was hoping just replace the problematic part instead of swapping the whole cluster.
There are specialized companies that will test and repair gauge clusters. You should probably pop yours out and send it off to one and have them fix it for you. Its probably a burned out solid state component, or broken solder connection on the board, etc.
Is the only thing wrong the speedometer? Do the lights work? Have you checked the fuses?
BTW - Electrical work is crazy expensive when you go to a shop to have it done. That's just the way it is...
