Sponsored by: CARiD
Overheating ..........
Old Aug 7, 2012 | 03:04 PM
1_MEANZ28's Avatar
Originally Posted by azvette89
I'm thinking it's gona be a fan problem, my car is running past 220 and when I open the hood only one fan is on. Weird because when I turn the AC off the driver side fan turns off and the passenger side then turns on. Anybody know the reason for that?
replace fans and loose the thermostat ull have water cycling always
Old Aug 7, 2012 | 04:37 PM
azvette89's Avatar
Are there any other relays besides the ones in the black fuse box that would cause the fans to not work? And I will get rid of the thermostat
Old Aug 7, 2012 | 09:26 PM
joecar's Avatar
If only one fan is turning on, then the other fan may have a short in its motor or in its wiring.
Old Aug 8, 2012 | 08:19 AM
spinya's Avatar
Have you checked both of the fans while unplugged? Check the resistance they have to make sure they arent failing internally? Hard wire them directly just to make sure they both blow with the same force? Then I would make sure they are well grounded.
Old Aug 8, 2012 | 03:02 PM
azvette89's Avatar
I got under the car this morning and seen that both the compressor and radiator were covered in a whole bunch of hay and junk. I used a brush to get it off and used some air from a compressor to blow out the rest of the junk. Couldn't start the car up because I tore both of the belts on the car so I'll replace and test the car out tomorrow.
