Sponsored by: CARiD
Flapper door on gas tank
Old Jun 27, 2012 | 05:47 PM
87 grand's Avatar
Default Flapper door on gas tank
Anyone ever have the tension on the flapper door not seal all the way ?
When I fill up, gas spills out. Do I need another fuel tank or is it repairable ?
98 metal tank.
Old Jun 28, 2012 | 12:10 PM
Jr.Samples's Avatar
98 metal tank.
Tryin to understand here,
When you are fueling gas shoots past the pump nozzel before shutting off?
Old Jun 28, 2012 | 04:56 PM
xBrandonx's Avatar
98 metal tank.
Mine's bent. I was putting STP Fuel Cleaner in and the bottle got stuck and long story short, the metal door thing got bent. My gas leaks out when I fill it up all the way and make a turn that makes the car lean to the gas side. I just only put 10 gallons in at a time now lol.
Old Jun 28, 2012 | 05:39 PM
87 grand's Avatar
Default tank
Sorry, let me explain, after filling up, gas will spill out the fill neck when making a turn. I thought there is some kind of flapper door inside the tank that keeps this from happening. I don't overfill, when the nozzle clicks, I remove the nozzle. Car shows no codes and it has a brand new GM gas cap for a 98 Camaro.
Old Jun 29, 2012 | 09:32 PM
Jr.Samples's Avatar
Gas is getting past your gas cap?
Look at vent tubes on your tank not operational
