Sponsored by: CARiD
Help... Gauges not working
Old Jul 13, 2012 | 12:15 PM
stealth1281's Avatar
Default Help... Gauges not working
For some reason my gas gauge, tach, and oil pressure gauge stopped working completely. I checked all ground wires and fuses. All the other gauges work fine. I'm stumped
Old Jul 16, 2012 | 12:14 PM
Wow, so nobody has a clue??
Old Jul 20, 2012 | 01:33 PM
zuuhlsT/A's Avatar
Check th e fuse for the instrument panel. If thats ok its the BCM Module. Open up your glove box, take it off the bump stops so it hangs down. You will see in back on the right hand side a black box with wires. Thats your BCM. Give it a light hit with something. If your gauges pop on, you know its the BCM.
Old Jul 22, 2012 | 11:50 AM
Thanks for the suggestion
Old Jul 27, 2012 | 01:31 AM
MJs1FastSS's Avatar
i have a low miled BCM if thats your problem
