Sponsored by: CARiD
Sputtering Under Load (RESOLVED! See Post #67)
Old Feb 22, 2013 | 05:49 PM
  #41
HibachiZ28's Avatar
Thanks fella's. I'll do some more looking and a compression test soon, as well as carb cleaner spraying for vacuum leaks.
I dropped it off at another local shop today. They put some time into it and are going to put some more work into it next week.
Just some info from my Torque app...
Freeze frame information:
Fuel Status = 0 byte
Engine Load = 6.667 %
Engine Coolant Temperature = 197.6 °F
Fuel Trim Bank 1 Short Term = 16.406 %
Fuel Trim Bank 1 Long Term = 24.219 %
Fuel Trim Bank 2 Short Term = -5.469 %
Fuel Trim Bank 2 Long Term = 13.281 %
Intake Manifold Pressure = 6.382 psi
Engine RPM = 1,608.25 rpm
Speed (OBD) = 34.797 mph
Mass Air Flow Rate = 155.214 cfm
Throttle Position(Manifold) = 11.373 %
End of report.
41* timing advance?!
Old Feb 26, 2013 | 04:15 PM
  #42
HibachiZ28's Avatar
Freeze frame information @ idle:
Engine Load = 2.353 %
Engine Coolant Temperature = 226.4 °F
Fuel Trim Bank 1 Short Term = -10.938 %
Fuel Trim Bank 1 Long Term = -7.812 %
Fuel Trim Bank 2 Short Term = -14.844 %
Fuel Trim Bank 2 Long Term = -8.594 %
Engine RPM = 755.5 rpm
Speed (OBD) = 0 mph
Mass Air Flow Rate = 53.824 cfm
Throttle Position(Manifold) = 0.392 %
End of report.
Per Tom Oates:
Old Feb 26, 2013 | 05:43 PM
  #43
sk8rax350's Avatar
I had similar issues with my previous M6. Have you checked fuses? Mine ended up being the 20A "ENG SEN" fuse in one of the boxes under the hood.
Old Feb 28, 2013 | 09:44 PM
  #44
HibachiZ28's Avatar
So if you're just reading this, #5 and #7 are the misfiring cylinders.
I purchased a compression tester today:
Only had time to do 4 cylinders, but everything checked out fine:
And the plugs ... 1-3-5-7:
Old Mar 1, 2013 | 12:03 PM
  #45
HibachiZ28's Avatar
I don't know what Mode $06 test results are but here are mine:
Mode $06 report generated by Torque for Android
Vehicle VIN: Not present
Vehicle Manufacturer: Unknown
Vehicle Calibration ID: Not present
Unit and scaling information are not supplied with the data from the ECU for this type of vehicle. Consulting the manufacturers service book for this information is recommended.
Test report:
TID:$02 CID:$04
- Lean to Rich sensor threshold voltage(constant)
Test incomplete or dependant test failed
TID:$02 CID:$10
TID:$02 CID:$11
TID:$02 CID:$12
TID:$02 CID:$20
TID:$02 CID:$21
TID:$02 CID:$26
TID:$02 CID:$30
TID:$02 CID:$31
TID:$02 CID:$36
TID:$02 CID:$40
TID:$02 CID:$46
TID:$04 CID:$20
- High sensor Voltage for switch time calculation
Max: 32,766
Test result value: 32,770
FAIL
TID:$04 CID:$30
Max: 32,766
FAIL
TID:$06 CID:$35
- Lean to Rich sensor switch time(calculated)
Max: 62
Test result value: 19
PASS
TID:$06 CID:$41
Max: 104
Test result value: 35
PASS
TID:$06 CID:$55
Max: 67
Test result value: 42
PASS
TID:$06 CID:$61
Max: 106
Test result value: 50
PASS
TID:$07 CID:$0c
- Minimum sensor Voltage for test cycle(calculated)
Max: 0
Test result value: 65,491
FAIL
TID:$07 CID:$0d
Max: 1
FAIL
TID:$02 CID:$04
TID:$02 CID:$10
TID:$02 CID:$11
TID:$02 CID:$12
TID:$02 CID:$20
TID:$02 CID:$21
TID:$02 CID:$26
TID:$02 CID:$30
TID:$02 CID:$31
TID:$02 CID:$36
TID:$02 CID:$40
TID:$02 CID:$46
TID:$04 CID:$20
Max: 32,766
FAIL
TID:$04 CID:$30
Max: 32,766
FAIL
TID:$06 CID:$35
Max: 62
PASS
TID:$06 CID:$41
Max: 104
PASS
TID:$06 CID:$55
Max: 67
PASS
TID:$06 CID:$61
Max: 106
PASS
TID:$07 CID:$0c
Max: 0
FAIL
TID:$07 CID:$0d
Max: 1
FAIL
End of report.
Old Mar 4, 2013 | 10:10 AM
  #46
HibachiZ28's Avatar
Took it to a fellow LS1 owner. He hooked it up to his EFI Live. He stated: "I hooked up HPtuners and monitored current misfires and #5 and #7 are misfiring badly. It sounds like to me he's either got a broken valve spring, or two, or a bent valve. I told him to get the driver's side valve cover off asap and see what's up before he does anything else. "
Old Mar 4, 2013 | 01:27 PM
  #47
lt1pwr1's Avatar
Time to get at it then. A couple of people have mentioned that in this thread including myself. If you have swapped coils, wires, new plugs and checked for power at those (and injectors) then it is time to test the mechanical aspect.
I would start with either a compression check or pull the valve cover and visibly inspect for broken springs.
Old Mar 4, 2013 | 03:12 PM
  #48
HibachiZ28's Avatar
Yep, I'm hoping it's a valve spring!
Read post #44 - RE: Compression.
Old Mar 4, 2013 | 09:20 PM
  #49
HibachiZ28's Avatar
Okay, photos of the valve springs:
7:
5:
3:
1:
Valve cover:
Old Mar 5, 2013 | 09:03 PM
  #50
HibachiZ28's Avatar
Finally got to #8. Nasty:
Runs better, drives better, but still misfires on #5 & #7.
Old Mar 6, 2013 | 02:58 PM
  #51
HibachiZ28's Avatar
UPDATE: SO, I think I may have found the issue, or a big part of it. I decided today to check things I have checked already, just in case I missed something, or see if anything changed. On my way home I stopped, unplugged the MAF, reset the codes on the PCM with my Torque app, and drove. WOW.... what a difference. CEL is not blinking, it's not even on anymore. I drove it 25 miles home. The car still has minor hesitation but no big misfire. Check out these screen shots:
I'll order up a new MAF and see if that fixes things completely!
Old Mar 13, 2013 | 03:01 PM
  #52
HibachiZ28's Avatar
Random question... I know carb cleaner is obviously flammable but should it catch fire when spraying it on the engine compartment? lol. I mean, that's a sign of a spark somewhere it shouldn't be, right? The motor wasn't really hot when I sprayed it either...
Old Mar 13, 2013 | 03:43 PM
  #53
wssix99's Avatar
Save the manuals!
You probably need a spark, depending on the chemical, but
http://www.engineeringtoolbox.com/fu...res-d_171.html
there are other sources of spark in an engine bay besides the spark plugs. The alternator has a lot of that going on, for example. You could have vapor start to flash in the alternator and spread to a spill site in another place.
Old Mar 13, 2013 | 03:55 PM
  #54
camarochvy21's Avatar
Just going throw this out there, but my car did sorta the same thing. Found out it was 2 leaky injector o-rings. Hope you get!
Old Mar 13, 2013 | 04:34 PM
  #55
HibachiZ28's Avatar
I grabbed some CRC carb cleaner:
It ignited on the passenger side, near the PCV hose and also off the manifold/coil pack area (Generic shot I edited with the arrows):
Thanks! How did you verify the leaking o-rings? I've swapped in other injectors (With different o-rings) and still have the same issue. No leaks I can see either.
Old Mar 14, 2013 | 02:37 PM
  #56
wssix99's Avatar
Save the manuals!
I wonder if the coil packs or static electricity could do it? I can't imagine that a stray spark would be related to this problem.
Old Mar 14, 2013 | 08:51 PM
  #57
I smelled fuel really, then took a closer look at all the orings around the injectors and saw that I had nicks on two injectors
Old Mar 18, 2013 | 05:24 PM
  #58
HibachiZ28's Avatar
Thanks, man. No fuel smell in the engine compartment.
I'm at the point where I am driving a Ford now... '13 "Gotta Have It" Green... I'm going crazy...
It's kind of nice driving a comfortable, reliable vehicle...
Old Apr 30, 2013 | 01:52 PM
  #59
HibachiZ28's Avatar
Just an update. No new news...
Old Apr 30, 2013 | 02:26 PM
  #60
lt1pwr1's Avatar
PM me if you want to sell her. Pass your headache on to someone else haha.
