lifters gone BAD
thanks, oreste.
Are you sure it's lifters or valves tapping? Every gm small block I've had starts to tick at some point but then 30k miles later it's tee same light ticking. I wouldn't stress over it unless it's loud and getting much worse.
yea its a brand new noise and the more i drive it the louder it gets, its not your normal valvetrain noise these cars are known for.
When mine finally died, I had a squeal at first, like brake squeal, not a tap. It changed to something that sounded like "popcorn" the sound you get from running rich. Eventually a "rocks in a can" sound followed. Two lobes was wiped/wrecked. To be honest I suspect cam hardening failure rather than lifter failure.
