Newbie owner LS1
I need to replace the AC compressor and i need advice which compressor is better cooling DENSO or DELPHI??
Also which headlight motor is better ACDELCO or CARDONE??
Thanks in advance
Plus - You can change the gears very easily.
Minus - The electrical connectors are horrible and will rust on you quickly. (Assuming Cardone hasn't fixed the problem yet.)
If the Cardone motors coming out of the factory today are like the ones I purchased, I'd recommend staying away from them!
