Sponsored by: CARiD
t/a heating up
Old Aug 8, 2012 | 08:31 PM
sharky.t/a's Avatar
Default t/a heating up
so i got a 99 t/a with an ls2 which starrted to heat up out of nowhere it dont leak any water at all from anywhere..and i checked the thermostat and it dont have one so im wondering what. i can be any suggestions??
Posted from LS1Tech.com App for Android
Old Aug 8, 2012 | 08:40 PM
FiredUpZ28's Avatar
Air pocket somewhere? Are all the hoses hot? Does it overheat at idle or driving? Fans coming on?
Old Aug 8, 2012 | 08:48 PM
sharky.t/a's Avatar
yes they told me about air pockets and how to fix them and yes hoses r hot but i noticed they dont have that much pressure on them...it heats up faster when driving. and yes fans are coming on
Old Aug 8, 2012 | 09:08 PM
FiredUpZ28's Avatar
With the radiator cap off (Cold) and engine running is there coolant flow? Water pump could be on its way out... Also check the radiator/condenser for blockage. In the first post did you mean you have no thermostat or just no leaks at the thermostat?
Old Aug 8, 2012 | 09:24 PM
sharky.t/a's Avatar
well i havent turned it on cold ...n yes it dont have a thermostat....i bought the car 2 weeks ago and it was working fine till yestersay and it had nothing but water when it started throwing it out yesterday when it heated up which i know its not good
Old Aug 8, 2012 | 09:37 PM
garygnu's Avatar
you need a thermostat !with out it the water moves too fast to absorb and remove any heat from the engine.get a stat and add the proper coolant.
By Brett Foote | 2026-06-04 05:00:17
