LQ4 Maintenance
Thanks!
Head gasket should be fine as long as it hasn't been sitting with the coolant lines un covered. Always a good idea to replace the water pump
I would replace the rear main seal and the oil pan gasket. They tend to dry uP after sitting for a while. When you pull the pan you will get an idea of how neglected the engine was or wasn't by the amount of sludge down there
