need chasis help!
If the book says its a half day job to get your car in, lift it up, remove the old bushings, clean it up, install, align, etc, then theyll charge you $90/hr or so for 4-5 hrs plus parts so yea depending on what arms you buy, its probably cheaper. If you can learn to do it yourself, its definitely worth it.
Example, dealer wants 800-900 to install a bushing on my diff - part was $65 and I did it in an evening with mostly normal hand tools.
Whether you just replace the bushings or install new arms, an alignment is necessary.
