So Many Issues....Where to start??
I do have HPTuners but have not used it to troubleshoot anything, still learning. I am actually waiting to go to the The Tuning School seminar so i can use it efficiently. But i can do some simple things and record for you all if that will help :/ Well here it goes...............
Reduced power mode all of a sudden at idle or while in low gears normally, also idle sometime stumbles down to 500rpm which I when it feels like it will go into limp mode soon
Sometimes, usually cruising, there is a studder in power, no change in throttle position just sudden slight loss in power
Stalling out while idle or when pushing in clutch after driving, rpms just plummet to a stall
Idle also stays too high ~1200-2000 rpm in motion sometimes, when I slow to a stop and the speedometer shows zero the idle drops and returns to normal ~850 rpm
low oil pressure sometime have seen it run as low as ~23 while idling, dont know if its an issue, but just checking
Loss of all gauges including a/c, radio except rpm, speed and voltage stay working
Lose temp gauge, maxes out and shows xxx in digital readings on dash
Overheating to ~220 while idling,
while cruising in 5th or 6th gear then pushing on the throttle sometimes service abs, traction ctrl system, and service active handling
Again all of these are seemingly sporatic issues!! They NEVER always happen when i do something. But every day AT LEAST one of them will occur. PLEASE HELP!!!!!
codes
10-PCM
P1221 H C
P1515
28-TCS
U1301
C1225
C1223
C1278
C1283
C1293
40-BCM
U1255
U1096
U1016
58-SDM
U1301
60-IPC
U1255
U1064
U1040
U1016
U1160
U1176
U1088
80-RADIO
U1016
U1064
U1096
99-HVAC
U1064
U1096
U1160 C
U1255
B0361 C
A0-LDCM
No Comm.
A1-RDCM
U1255
U1064
U1016
U1096
A6-SCM
U1300
U1016
U1064
B0-RFA
U1255
U1096
