Whine from power steering pump??
I bypassed the coolant unit and flushed both the radiator and power steering systems.
Now, after the engine warms, the power steering pump whines a bunch. This gets louder when you turn the wheels a lot...
Anyway, I suppose it is time to change the power steering pump; right?
I would think this further confirms a bad pump.
I will use a stethascope to confirm.
I have 315 sized tires on the front. Does this stress out the PS pump? Most here have concluded that F-body cars do not need a PS cooling unit. Does this apply to cars with 315 sized tires on the front?
How much of a pain is it to remove and replace the pump? I can't find any videos on YOUTUBE.com????
If you look at this article: http://www.gmhightechperformance.com..._pump_install/
the folks who do P/S pumps for a living give concrete numbers that point to the stock fluid temps being high enough to degrade the pump seals. This is why GM moved to the cooler in later years for all V8's. I'd tend to side with Turn-One and GM's engineers on this one, which is why I've retained some cooling.
The pump is one of the easiest things to remove on the entire car! No video is necessary. However; the P/S pulley needs to be removed from the pump first. That is a TOTAL PITA. You'll need a P/S pulley remover to do the job, which should have instructions for you.
