Sponsored by: CARiD
"Low Oil" Light
Old Sep 4, 2012 | 07:08 PM
J8127's Avatar
Default "Low Oil" Light
2001 LS1, 32k miles, friggin damn Low Oil light is constantly coming on. Dipstick reads fine and pressure stays at the 3/4 mark most of the time (which I assume is 60psi?) I've already replaced the sensor once.
Old Sep 4, 2012 | 07:15 PM
DisasterFormula's Avatar
Check for corrosion in the connection.
Old Sep 5, 2012 | 08:01 AM
FiredUpZ28's Avatar
^ Yup, or a bad sensor. Hell, probably needs both.
Old May 28, 2013 | 08:05 AM
American-Muscle1989's Avatar
Hey buddy,
I had this problem with my 98, from cold the light would stay on. If I started the car, warmed it up, then turned off the engine, locked it, unlocked it, turned the engine on again the light would disappear. So this is is what I had to do because I didn't want the light to be on whilst I was driving incase at any point the oil really did become low and then I wouldn't know.
An interesting event happened last week though, the key must have had some dirt on it and the car did not recognise the chip so it went into security lock down. I researched the problem, gave the key and barrel a clean and it was fine. Now ever since then the oil light is on at the lights stage and then goes out when the engine turns on, just like it is supposed to do!
Spooky and what a result so the whole thing has worked out great for me.
I am not sure how you can induce a security lock down on purpose but if there is a way then it worked for me.
Thanks
Old Jun 24, 2014 | 01:10 AM
knight_rider's Avatar
This might be the issue with my ride since my 'low oil light' just came on and I just changed my oil and the light is still on but I have no idea where this sensor is...anyone know where its located? Thanks.
Old Jun 24, 2014 | 05:26 AM
Triaxle's Avatar
Its down on the passenger side of the oil pan
Old Jun 24, 2014 | 07:40 PM
Thanks!
Old Jun 30, 2014 | 10:37 PM
conde'strans's Avatar
Originally Posted by American-Muscle1989
Hey buddy,
Thanks
This is exactly what my 98 does when cold, I then turn it off and back on and the light is gone!
