Sponsored by: CARiD
Window Not working HELPPPP!!!
Old Sep 10, 2012 | 04:39 PM
WSUHottBOI's Avatar
Exclamation Window Not working HELPPPP!!!
Alright so I have a 1998 Trans am. When I bought it the passenger window found go up and down really slow like sometimes it would take a couple hours to put my window up. Then it finally went out so i replaced the window motor and it started working perfectly fine but then 2 weeks later when I tried putting my window down it didnt work. It doesnt move at all or make any sound. Then i bought a USED window switch and still nothing. Anyone have had a problem like this before? Please help..I think its either the used switch, relay, or cheap window motor. I dont know where to start
Old Sep 10, 2012 | 05:13 PM
gyrene2003's Avatar
Cheap motor or some sort of electrical connection problem. For it to not work at all I would lean towards the later. U get a warranty on the motor? Maybe take it back and trade for another. Atleast u could eliminate if it was the motor or not.
Old Sep 10, 2012 | 11:02 PM
fatjet00's Avatar
check and make sure you have 12 volts of power going down to the motor. That will tell you if your switch is working.
Old Sep 11, 2012 | 10:03 AM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
I would lean towards an electrical issue on that one. You would think the motor would still try to do something even if it was on the way out again. I could be wrong but I would at least check connections and voltage first.
