P0430 & P0332 help!
Been reading a lot of info on these codes here. Trying to dia and figure out what to do. The cats are from 2010. Hard to believe one is bad. Catback system with catco. Ive had a lot of camaros. This problem always pisses me off the most. I usually just get an inspection from an awesome place and just ignore codes. Im tired of that. I just want to pull in and get my **** inspected and move on. New cats? New Pre O2 sensor? What should I do?
Car sounds like its got an intermittened sputter when slowing down only and or stopped at a light. RPMs dont move up or down when sputtering is present. Still getting 320 miles or so to the tank on the HWY. Where should I blow my money first? ****! Thanks if you can point me in the right direction
SOME cars have ECM reflashes that enhance certain DTC diagnostics (although I dont believe F bodies had an issue...)
Then it was idling like poop at 5mph. Just up and down up and down, without giving it gas. Finally went away a mile down the street. Not sure if taking the intake off has effected the TPS. This **** will literally run you in circles. madness. Help accepted
On your way to the facility never let the car sit idle for more than 30sec - blip the throttle just enough to raise the rpm a few hundred rpm.
For the code to be triggered, the car must be running for a min of 10 min, must be at operating temp, and the car must be sub 1000 rpm +/- a certain range (maybe 100rpm?) for a min of 2 min. If you blip the throttle at stop lights, itll reset the diagnostic run. In theory, you could keep the light off forever with NO cats if you drove all short distances, only highway, or never stopped for more than a min. Good luck.
