maf fuse keeps blowing
it could be a wire going to the maf thats shorting out, or the maf itself is shorted. Try unplugging the MAF, install a new fuse and see if the fuse still blows.
Do you have long tubes? Your headers have probably melted the insulation on the O2 heater circuit wiring and shorted it to ground causing the fuse to blow. Jack the car up and trace your wiring. Don't forget to check the rear O2's as well. The rears may be rubbing up against the transmission crossmember.
