Sponsored by: CARiD
weird noises
Old Sep 25, 2012 | 02:37 PM
Rated Z's Avatar
Default weird noises
okay so i've had this ongoing problem ever since i brought the Z out in April of this year. The caar has 26k miles on it and has never been wrecked. I had this noise coming from the car typically when turning corners hard and decelerating. Also had poor traction around corners. So i figured it was the tires. I ordered brand new wheels and tires from Oewheels.com and they look good. But my car still has the same issues i don't think this could be related to the tie rod because the wheels are tight with no slack present. I have also installed new rotors and pads. It seems now and before the tire would spin freely when the car was lifted but not for long there is brake rub present. It also seems the new brakes still rub a bit but i have not driven on them much to really brake them in. So i'm here to ask for some help diagnosing my problem, i have probably left things out. So please answer my questions as to what this issue is! and i will answer anything i have left out. Also the car seems to be aligned fine drives in an almost perfect line when i let off the wheel.
Thanks!
Rated Z
