Ls3 starter
I ran across a thread on here where a member used an ls3 starter on his project (l99/t56) in a c4 vette. The ls3 starter can be had brand new for 120 bucks from ac delco. Does anyone see an issue with running the stock ls3 starter? The connector pigtail is a little different but thats not a big deal. I'm just wondering if the mounting location and all would be the same?
The starters are all PG260M. the length of the body/motor has varied, the longer ones are more powerful I think 1.4kw or 1.7kw. also the thing that usually craps out is the electromagnet solenoid on the starter. the armature and brushes and gears inside are basically bulletproof.
