Sponsored by: CARiD
Engine noise (video)
Old Nov 1, 2012 | 09:51 PM
Juanmiguel's Avatar
Default Engine noise (video)
I have a 2000 LS1 trans am and there's a weird noise coming out of the passenger's side valve cover area (i think). I'm guessing it could be a rocker but I haven't found any videos that sound like this.
The engine internals (valvetrain, cam, heads) are stock, it only has a few bolt ons (LS6 intake, headers, lid, tune). Both belts were replaced around a month or two ago.
has anyone seen anything like it?
https://www.youtube.com/watch?v=OGrS1bNz1nM&list
Old Nov 2, 2012 | 12:42 PM
03Sssnake's Avatar
That is weird...pull the passenger side valve cover and check. You may also have a bearing issue on idler/tensioner pulley etc..
Old Nov 2, 2012 | 01:01 PM
Juanmiguel's Avatar
Yeah I think I'm going to take the belts out and see if it still does it, then try the valve covers. I could swear it comes from the valve cover area, but that kind of noises are always tricky.
Old Nov 26, 2012 | 07:46 PM
subtractison's Avatar
I'm having this exact same issue - did you ever figure out what the problem was?
Old Nov 26, 2012 | 08:20 PM
Juanmiguel's Avatar
No, i havent pulled out the valve covers and it still does it.
Old Dec 2, 2012 | 10:03 AM
Jays_SSZ28's Avatar
Sounds like the air gap is too close on the a/c compressor clutch.
My s10 was making a noise similiar to that after installing a cheap reman compressor.
I found this during a search for the a/c tensioner info, I've tracked a noise down to that on my car.
Old Mar 21, 2013 | 05:46 PM
Juanmiguel's Avatar
Update:
1. We tested without the belts and the noise is still there.
2. We did a cam swap, used brand new cam, springs and rods and the noise is still the same. All the factory rods, cam lobes, rockers and springs came out intact. No traces of damage or excessive wear on the cam lobes that could indicate a faulty lifter.
Old Mar 21, 2013 | 05:57 PM
Juanmiguel's Avatar
After an hour or so of going through similar threads and videos I found a video that sounds similar to mine:
http://www.youtube.com/watch?v=aaHMf...ature=youtu.be
On the original thread it says it was an exhaust gasket leak. I guess I'll check that too.
Old Mar 22, 2013 | 06:57 AM
Default Solved
That video sort of sounds like my car did. I took mine to a local shop and after lots of investigating found out that three of the driver side pistons had gotten warped and were rubbing/grinding against the cylinder walls of the block. Still waiting to get the car back, but I can't imagine it could be anything else.
Here's a video I took - not very loud but you can still hear it every time the engine is revved.
Old Mar 22, 2013 | 10:19 AM
Juanmiguel's Avatar
Wow hopefully that's not my case. Thanks for the video, it gives me another idea on what could be happening to it none the less.
Old Mar 22, 2013 | 11:59 AM
Juanmiguel's Avatar
Yup, it was the exhaust. The header bolts didn't seem to be tightened all the way. Now the squeak, noise or whatever is completely gone.
Thanks for your input guys.
