Overheating/not holding coolant
Thanks,
(i been searching)
. The hole, I tried to take pics with my phone ill get better ones tomorrow after I take the head off. So any ideas on how this happened?
I had similar issue, in my case it was the water pump. It is quite difficult to see if the water pump is leaking a tiny bit. I found that with a good torch i could see that the leaking water had cleaned a small patch under the pump. There is a weep hole on the lower part of the pump. where the water leaks out.
The heater pipes near the bulkhead are also a likely candidate. Make sure the rad cap and the overflow tank/pipes are secure and in good condition.
If it is the water pump?
After advice from members on the forum re. cheap online/Fee bay pumps, i went for a Blueprint one.
see you with a good connection.....
If somebody has got better knowledge regarding this mater please give your suggestion......
ND pajero
