- Camaro and Firebird Why is Car Overheating<br>Guide to diagnose trouble and recommended solutions.
LS1 Camaro Overheating
Does anyone have any ideas?
id changed the thermostat. Could be not opening enough anymore. system could have a blockage or possibly the case could be a water pump that **** the bed.
did you happen to do any work to the fans themself? if wired backwards, they will push air the wrong way. ive done that. :/
You say "the fans were not turning off", and then you turned the A/C on to "kick the fans". What does all that mean? I'm guessing you meant to say that the fans were not turning ON, and that you then turned the A/C on to try and get the fans running?
Either way, 200-210° on the gauge is normal, and represents an actual coolant temp anywhere between about 190° and 230°.
But if the fans are not cutting on even when the engine is hot enough to blow coolant out of the overflow, then your problem likely lies with the fan system. And if turning the A/C on gets the fans to run and then solves the overheating, this is further indication that the problem lies with the fans.
Well the temp sensor did work when i changed it. Now it wasnt working at all so i assume it was from a large air pocket in the cooling system. Brought the car to my buddy at the local sport chevy dealership and were running all the tests. My coolant overflow resevoir was full but when i checked the radiator it had very little coolant in it. I ordered a new GM radiator cap instead of the garbage one i got from the store. IF that dosent fix the overheating issue than its probably a new radiator (we did a fan check and all 3 are running the way their sapost to)
$96.00....rockauto.com
SPECTRA PREMIUM / COOLING DEPOT Part # CU1486
$103.00....rockauto.com
PRO Part # 8011486
