Sponsored by: CARiD
WD 40 damage O2 sensor?
Old Nov 8, 2012 | 07:41 PM
Crimsonnaire's Avatar
Default WD 40 damage O2 sensor?
Can WD 40 damage LS1 O2 sensors?
A lot was sprayed into the exhaust when they were trying to get out a stuck exhaust bolt at the bottom and immediately experienced afterfires on startup and the codes P0300 and P0134/P0131.
Thanks.
Old Nov 9, 2012 | 09:10 AM
wssix99's Avatar
Save the manuals!
Damage - no. Prevent from doing its job - yes. If it was coated with oil, that would be a problem...
Not sure if it can be remedied. Probably easier to replace the whole sensor, if its fouled.
Old Nov 9, 2012 | 09:13 AM
Reckless's Avatar
Super Moderator
You could try cooking it with a torch or something to clean it up. otherwise, replace it.
