some kind of electrical issue
it does it as soon as i turn the key to the start position.
only does it once and then its silence and everything goes dark.
also after i did it there was a kocking noise coming from somewhere in the engine, cant figure out where or what it is... sounds like its coming from the air filter area, even tho i know its not because a air filter doesnt knock...
also at the same pace of this knock all the dummy lights on the dash would flash.
any ideas? this car is becoming a nightmare...
In any case i would pull the starter off the engine (disconnect battery first) and have the starter tested. you may need a new starter. The other thing is the starter relay in the underhood fuse box but if it was this that's usually turn the key to start and get no noise but all lights stay bright.
