Sponsored by: CARiD
terrible squeak
Old Jan 10, 2013 | 08:34 PM
JerseyLS1TA's Avatar
Default terrible squeak
Ok so there is a terrible squeaking noise that I need help identifying. I've replaced the belt, tensioner and idler pulleys, still there. It only happens in the cold weather, it gets less noticeable at idle but screams under acceleration. It also happens if its damp out but goes away only if its warm out. Its embarrassing lol..any ideas?
Old Jan 10, 2013 | 08:43 PM
WS6nTX's Avatar
Fran Drescher didnt hide in your engine bay to keep warm, did she?
Have you tried spraying wd40 or some type of lubricant spray on each pulley as the motor runs? this happened on my cavalier..since i had the pulley assembly from a cobalt (i supercharged it) the idler pulley was the culprit. after spraying it, the squeak has been gone for months.
Old Jan 10, 2013 | 09:09 PM
trans_am7935's Avatar
remove your A/C belt if it is still attatched and see if that solves it, otherwise i would think the water pump. my car did the same thing, only when it was cold but i solved mine by going with a high quality belt. problem solved!
Old Jan 11, 2013 | 06:18 AM
Still does it without the ac belt, I was thinking water pump too but I'm gona try another belt first, and recommendations? Also I was told to try a smaller one to help keep tension?
Old Jan 11, 2013 | 08:50 AM
wssix99's Avatar
Save the manuals!
I just had a similar squeal and it was a bad bearing in my alternator...
To locate the source, you can either use a $15 mechanic's stethoscope or put a long metal rod up to your ear. (This is a little more hazardous.) You can then probe by touching the cases of the alt, p/s pump, water pump, etc. to find the source. Either method will amplify the sound coming from the specific component.
Hopefully, just 1 will be noisy!
