Radiator??
I've had one in mine for almost 7 years....cools great.
Installs 100% the same. Just have to cap off one extra port with a 6 inch piece of heater hose, a brass plug and a clamp.
Other than that....$300-$600 for aftermarket custom radiators, which will not really do anything better than an LT1 or LS1 radiator if the cooling system is working properly with no issues in the system.
Picture shows the extra port.....it makes a GREAT flush port. This is when I had a plastic plug in the end, but buy a brass plug that fits, then clamp it.
Its the same price, or damn close......just do the LT1 radiator. Its the identical radiator, just a little more capacity.
Its a no brainer.
Just go to rockauto.com and order a 1997 LT1 radiator. It should have every port the LS1 has and the same exact place for the coolant level sensor....and that one extra port I showed you in the picture to cap off.
Or just do an LS1 radiator and make sure the cooling system is operating properly and you'll run nice and cool.....190*f-200*f is good FOR CITY DRIVING, 180-190 while cruising steady at say 70mph is good.
As far as the part number goes, just go in to the store and ask for a radiator for a 97 z28 and you'll get what ya need. Oddly enough when I did my car the 1st time I just asked for a new radiator for my 02 and the one they gave me WAS the lt1 style and the same thing happened again when I got one for my cousins 2000 ss. So I think for easement purposes if you get one from a store they just all use the same part number no matter the year and you just get the thicker one. Make sure to get the coolant blockoff plugs for the hose nipple on the bottom.
Dan-
