Sponsored by: CARiD
Steering wheel replacement
Old Jan 15, 2013 | 10:11 AM
BlackedOut LS1's Avatar
Default Steering wheel replacement
What is the process to replace the steering wheel in a 98 Trans Am, are there any complications because of the airbag? My steering wheel looks pretty raggedy and I need to purchase a new one. Or get a steering wheel cover from redline which looks to be more expensive than a new steering wheel. Thanks
Old Jan 15, 2013 | 11:16 AM
Spartan7's Avatar
Pull the air bag fuse, then disconnect the yellow air bag connector under the steering column. This ensures the air bag will not deploy. You'll need a special steering wheel puller to remove the wheel itself, any auto parts store will carry it. It's not a very hard job at all.
The steering wheel splines are keyed to help you line it back up. But you can force it on the wrong way, so be careful with that. It helps to put the front wheels pointing straight forward before removing the wheel.
Old Jan 15, 2013 | 08:19 PM
Thanks man I appreciate that, I will try it tomorrow.
Old Jan 16, 2013 | 07:54 AM
wssix99's Avatar
Save the manuals!
https://ls1tech.com/forums/general-m...mn-repair.html
https://ls1tech.com/forums/general-m...oval-pics.html
Old Jan 19, 2013 | 08:54 AM
theMOSTWANTED's Avatar
Also I would check the wheel alignment too. Make sure the old steering is aligned straight along with the front wheels. This is so you won't force it on the wrong way. Just my .02.
