Sponsored by: CARiD
Windshield Nozzle
Old Feb 1, 2013 | 08:13 AM
LS1SSZ28's Avatar
Default Windshield Nozzle
I replaced the passanger side nozzle due to a weak flow, but it is still barely spraying. What is my next step in fixing this?
Old Feb 1, 2013 | 09:34 AM
AmDWs6's Avatar
maybe it's clogged? try to clean the lines and see if that doesn't change anything
Old Feb 1, 2013 | 06:43 PM
RyderTA's Avatar
I fought this myself, my nozzle was clogged and I used a piece of wire to clear it. I also had a leak under the windshield cowl, get a bright flashlight and look through the mesh while someone sprays and make sure it doesn't leak.
Old Feb 2, 2013 | 07:20 PM
wssix99's Avatar
Save the manuals!
Are both nozzles weak?
If so check the screen on the bottom of the pump. If not, put the hooked up nozzle in a cup of water and use a vacuum pump near the washer fluid tank to suck the obstruction backwards through the system.
Old Feb 4, 2013 | 08:14 AM
LS1SSZ28's Avatar
No the drivers side nozzle works perfectly, just the passanger side one and i just replaced it so it has to be something leaking or in the line.
Old Feb 4, 2013 | 11:17 AM
C4 LS1's Avatar
Ya it sound like a leak in the wash line after the first nozzle.
Old Feb 4, 2013 | 11:21 AM
LS1SSZ28's Avatar
Ok sorry for a dumb question, but where would i check for this leak? and what are my options in replacing the hose or fixing it.
