Sponsored by: CARiD
coolent change
Old Feb 27, 2013 | 06:34 PM
spdygon's Avatar
Default coolent change
ok need to change coolant....i have alway just drain coolant and refill it again on other cars. will this work or is their another way to do it on my 01 ss?
thxs
Old Feb 28, 2013 | 07:13 PM
spdygon's Avatar
guess no special way to do it.....
Thanks everyone
Old Feb 28, 2013 | 07:35 PM
Cajun ELESS-ONE's Avatar
if ur going from dex cool to dex cool just make sure the new dex cool is compatible with the older fluid. if ur going from dexcool to the green antifreeze then you want to flush the old dex cool out REAL well. if not the dexcool and green antifreeze will mess up ur gaskets. after the flush just fill the radiator up but leave the cap off and squeeze the top and bottom radiator hoses to get the bubbles out. you will see the bubbles burp out and refill till its topped off. start up the car leaving the cap off and let it idle till the t-stat opens up and top off as needed. tturn off the car, put the radiator cap back on and fill ur coolant overflow tank. drive it around town for bout 20 minutes. let it cool down and open the cap and see if you need to add any coolant. its not hard. main thing is to get the bubbles out.
