Sponsored by: CARiD
Window motor
Old Mar 7, 2013 | 11:13 AM
blackws620's Avatar
Default Window motor
So does anyone have a cure for the diseased window motors in these cars. It seems like i have replaced the driver motor 4-5 times. Does anyone else have this problem with them?
Old Mar 7, 2013 | 11:43 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
No, nothing that serious.
I had to replace the driver's side motor at about 90-95k miles, and so far the replacement (Dorman) has been fine. The passenger side one is still original at 105k miles.
I wonder if something on yours is causing an excessive drag, like thick tinting paper or a regulator that is in dire need of lubrication? Or maybe you just roll them up and down a lot.
I also make it a habit to only operate one window at a time, so there is less voltage drop and thus more power for each motor.
Old Mar 8, 2013 | 08:26 AM
wssix99's Avatar
Save the manuals!
^ Great advice. I think the Dormans have been out for 5 years now and I have yet to see a situation where one has failed.
Odds are the other ones you have been using were remans.
Old Mar 9, 2013 | 08:31 AM
AmDWs6's Avatar
i has auto trix w/ dorman motor's
can't be happier !
VERY great.
Old Mar 9, 2013 | 09:19 AM
Nathan C's Avatar
Advanced sells remanufactured motors with a lifetime warrenty on them. I think they are about $145 and there might be a core charge.
