Sponsored by: CARiD
A/C help
Old May 7, 2013 | 01:43 PM
MFJ's Avatar
MFJ
Default A/C help
My compressor runs and my lines are doing what they are supposed to (hot and cold) but there is no cold air in the car. My fans do not come on when I turn on the a/c either.
I have 3 fan relays in the car. A high speed, low speed and a/c. I'm assuming the a/c fan relay is the 5 prong relay? I haven't heard my fans come on in a long time and my car takes a long time to get to temperature as well.
This is my first step in diagnosing the problem I guess unless anyone else has any ideas?
My temp control works when the a/c is not on. It does go from hot to cold with out the a/c.
Old May 7, 2013 | 07:27 PM
Homeless2bNY's Avatar
fan only runs when temp set to hot?
or fan never runs is ur problem?
if so, give the fan direct power and check motor is ok.
if fan works, swap relays with a diff one to see if its a relay problem.
Old May 8, 2013 | 05:34 AM
MFJ's Avatar
MFJ
I had relays here at work. Changed all 3 relays. Fans never came on. I'll check the fan motors today and see if that helps.
Old May 8, 2013 | 08:53 AM
the blower motor relay is under the dash on the passenger side btw.
i have no idea what 3 relays ur talking about, but they have nothing to
do with blower motor in HVAC system.
check all ur fuses btw.
Old May 8, 2013 | 09:24 AM
MFJ's Avatar
MFJ
These are the actual cooling fan relays under the hood not the blower motor. Blower motor works fine.
When you turn the a/c on the fan should come on to keep the condensor cool.
Old May 8, 2013 | 12:54 PM
so fuses are good then?
do u know how to check for power at relay?
do rad fans never come on?
you drive it, cars gets hot.
cooling fans never kick in?
turn on car, while someone else is in inside cycling AC on and off,
touch each fan relay and feel for a click.
if nothing= no power signal is given to turn on fans. problem is between switch and relay.
if clicks= fans are bad or broken wire. remove connectors to fan and check for power and try and power up fan direct like i said before
Old May 8, 2013 | 02:39 PM
MFJ's Avatar
MFJ
Got the fans to come on finally. Still no cold air. Compressor continually runs so I'm gonna check my pressures and go from there.
