Zerex G05?? Before you start... NO IM NOT GOING TO USE DEXCOOL With that said, im looking a the Zerex G05 coolant. Ive read a bunch of guys using it when they convert from the orange stuff. Any opinions on this stuff? Is there something better for out engines??? (SHUT UP DEXCOOL GUY) |
If you are set on the G05 (and I would ONLY use the Zerex brand in this), make sure you COMPLETELY flush out the WHOLE system (YES, I would even bother pulling the threaded block plugs) a couple of times and then finally with distilled water before installing said G05. I've also heard some people have had luck with the Peak Global Long Life stuff as well. |
Originally Posted by DirtyBirdMKE
(Post 17505958)
Is there something better for out engines??? There are several options out there. Our cars came from the factory with a great daily driving formula that enabled 100,000 mile/7 year performance. (This came at the expense of cost and anguish for whoever went very far beyond that 100,000 mile/7 year window with the stuff.) Depending on your cost, change interval, and usage requirements, there are different choices for you on the market. |
the car is a street car that will get occasional AutoX and Track day use.... i will be going to my friends shop to flush everything with distilled water. |
The Evans fluid and pump are another option, especially for open track use, but their fluid does get mixed reviews depending on who you ask, and WHERE you live (for a year 'round daily driver like mine is ;) ). I would suggest at least the thicker than our stock LS1's, LT1 radiator, if not one of the primo, big buck, wider, larger tubed, fully welded, alloy tank, radiators (i.e.; Griffin, Be Cool, Ron Davis, DeWitt, etc.) for extended open track use, especially if your factory stocker is leaking now, or due to be replaced soon. |
(Post 17511116)
the car is a street car that will get occasional AutoX and Track day use.... |
better cooling, better overall performance.. my toyota is my daily.. I live in wisconsin. Winters are for upgrades.. and looking at it in the garage |
The Zerex G05 is ethylene glycol. The exact same stuff as is in most other green antifreezes; just with different additives. So, its a good choice if you want a green coolant that will last a long time, but it won't give you better cooling than anything else. (All the manufacturers say they give "superior boil-over protection," etc., which they can do when compared to water.) As dailydriver pointed out, the pathway to better performance is mostly mechanical. |
The HOAT G-05 has problems just like DEX-COOL. I'm a Ford tech so I've been dealing with it since late 2002 when Ford decided that's what they were switching to. It doesn't drip or stain with small leaks. It turns into a light brown crust which means small coolant leaks often go unnoticed, and small coolant passages clog easily. It's also a big contributor to the Ford 6.0 EGR cooler failures and 06+ Explorer cooling system issues. Ford stopped using it years ago. Stick with the tried and true green coolant if you don't want to use DEX-COOL. |
thanks Marc... |
why the hell didnt i think of that??? |
© 2024 MH Sub I, LLC dba Internet Brands
