AC Compressor kicks on and off at idle/high temps
Thoughts?
Thoughts?
the smart thing to do would be to put a set of gauges on it and monitor high/low pressures when it happens. when it's 100° outside at idle, if you watch your low side pressure go below 30 psi while high side is over 200 psi then you are low and need to add a few ounces.
when your idling and everything is hot and the ac compressor is pumping, you'll see high side pressure creep higher and higher until the radiator fans kick on high speed then high side pressure will drop and the radiator fans will drop to low speed. if this is happening, then your condenser is clean and working fine. what also tells me it's clean is you say the problem doesn't happen when you're cruising.
At idle the suction and head pressure go through the roof in 100+ outdoor ambient.
Also use a amprobe to check both cooling fans and verify they are both working. If one fan motor is dead the dead fan will almost turn as fast as the operating one causing your exact scenario problem. Pulling amp loads verifies each motor is working correctly and they should be pretty close in readings one motor way higher than another means you could have one motor getting weak or one pulling waaay too much and failing when it heats up
