DRLs no longer working
Is this a Camaro or Firebird? Are you the first owner?
Is it your front marker lights that come on, or do your fronts/rears and your rear tail lights come on also?
The DRL module controls the turn signal bulbs only.
If the DRL module only controls the turn signal bulbs (larger 3157 bulbs), wouldn't that be a possibility if the turn signal bulbs are no longer DRL?
So... If there was a short from the DRL/Turn wire to the wires to control the Parking (and marker) lights, they should all illuminate and blink in unison.
