Sponsored by: CARiD
TransAm LS1 2000 many error codes
Old Sep 4, 2013 | 07:15 AM
Bilmos's Avatar
Default TransAm LS1 2000 many error codes
Hello,
I hope someone can help me.
The car starts but when the clutch is dropped the car dies. It has these error codes:
PO335 Crankshaft position ckp sensor circuit
PO418 Secondary air pump control circuit
PO645 air conditioning a/c clutch ralay control circuit
PI637 Generator l-terminal circuit
U1016 loss of PCM communications
any ideas what this might be ?
Old Sep 5, 2013 | 04:05 PM
Bilmos's Avatar
Really no clue at all ? Ive checked all wires and put some more ground electric but still it dies when releasing the clutch. ( sorry bad english)
Old Sep 5, 2013 | 06:05 PM
2000PewterT/A's Avatar
Start diagnosing each system, check connections. There is no clear cut cause.
Old Sep 6, 2013 | 09:52 AM
lt1pwr1's Avatar
The code PI637 Generator l-terminal circuit probably means you need a new alternator or the exciter wire (little red wire on top) has broken off and needs repair.
I bet this in turn has drained your battery, hence the loss of comms with the PCM.
Your A.I.R. codes I would not worry about right now.
Your code PO335 Crankshaft position ckp sensor circuit - is something to worry about but if you really had a problem the car probably wouldn't start at all.
NEXT STEPS:
Fix your alternator issue
What RPMs does your engine idle at in neutral (without pressing the clutch)?
Is your car stock? Any work done recently?
