VSS Issue
I just got the car back from the shop getting some parts installed and the tech says that all the wires for the vss are good, the sensor itself is working but the issue lies with the reluctor.
Has anyone had a problem with this. They say that the VSS doesn't seem to be getting close enough to the reluctor to get a solid reading. They are getting a reading on their scan tool but the reading is very weak. Are their different sensors available that have different depths?
https://ls1tech.com/forums/general-m...onnectors.html
Back to the vss. The only code throwing is P0500. It is possible the previous owner swapped transmissions at one point? Do different year t-56's have different size reluctors in the tail shaft? This would explain the signal/voltage being too low.
Anyone have any ideas.
