98 T/A creaking/squeaking
1. Sway Bar bushings: try lubing with silicone spray as a test - if makes squeak go a way, then replace bushings.
2. Upper strut mounts: fixed by replacing a trapezoidal shaped rubber part called "strut mount" located inside the actual steel mount just below the top nut of the strut assembly (Gabriel PN 142412 from AutoZone).
