Sponsored by: CARiD
02 camaro pulls to the left after alignment and power steering replacement
Old Feb 14, 2014 | 09:00 PM
RockinWs6's Avatar
I had 2 LS1 cars that had alignment problems that couldn't be addressed on a alignment machine SPECS. Both were wearing the passenger frt tire on the inside edge. After trying 3 different alignment shops and watching them check it I fixed it them at home by going outside of the factory specs.
Never wore the tires again and handled great.
Old Feb 21, 2014 | 09:06 PM
Bigbee's Avatar
I had bad tire pull after installing some cheap khumos with directional treads on the front. Didn't realize it was the tires until 2 different shops did alignment with same results. Khumos are on the rear now and all's well.
Old Apr 11, 2014 | 11:00 AM
gollum's Avatar
Some directional tires will cause tire pull. Non directional tires will prevent tire pull.
Old Apr 12, 2014 | 08:53 PM
Mongoose350's Avatar
Okay I just skipped to the bottom after reading a few responses, so this may have been mentioned. I am having a similar issue that is being caused by an inner tie rod. Maybe check those out? Sorry if you already cleared them.
