Sponsored by: CARiD
Strange problem!!
Old Jun 20, 2014 | 06:43 PM
joecar's Avatar
The other possibility is excess crank endplay (crank thrust bearing worn) which allows the crank to move forward just enough that the reluctor does not quite line up with the CKP sensor.
You can check endplay by gently prying at the crank pulley/damper to bring all the way forward and then measuring how far back it moves (need to borrow a dial gauge).
Old Jun 21, 2014 | 07:19 AM
jm01z28's Avatar
Originally Posted by RatCityRex
How many keys do you have on your key chain? I've seen this so many times. To much weight and it wears out ignitions. Just a though. Dad had a similar problem with his 06 silverado and it ended up being a bad connection with his bcm.
I only have 2 small keys on the key chain and they are not heavy at all.
