Sponsored by: CARiD
Diag assistance please!
Old Mar 9, 2014 | 11:39 AM
Simmsjhc's Avatar
Default Diag assistance please!
Hello, I know a bit about cars but am having an issue I cant diag. When I accelerate and the RPM's reach exactly 2 there is a slight vibration sound coming from the passenger front wheel area. So far I seem to only hear it from inside the car. This happens every time the vehicle hits 2 RPMs but only when my foot is on the gas pedal. If I rev it up past 2 it does not make the noise as the RPMs lower below 2. I know my Idle air control valve is bad (I'm replacing it today) but I cant think of any other issues I've had with this car. I'm thinking it could be perhaps a broke or loose motor mount but for it to be so consistent with the 2 RPMs I'm not sure . I have tried hitting the gas hard to see if it still makes the noise and I have tried very slowly reaching 2 RPMs and both times it still makes the noise. If anyone has any suggestions I would greatly appreciate it. - Jess
1998 Saturn SW1 160k miles
Old Mar 19, 2014 | 10:42 PM
Jrclayton's Avatar
Can you feel the vibration in the steering wheel? Make sure the front passenger tire has the appropriate wheel weights on it. I know it sounds weird but if its unbalanced it isnt impossible for it to only vibrate at a certain rpm but it sounds like it could also be a worn strut. Its hard to diag these types of issues without actually driving the car.
Old Mar 20, 2014 | 03:22 AM
chrysler kid's Avatar
Exhaust heat shield is loose, or the 02 sensor is going bad, or the cat is going bad, or the exhaust gasket is bad.
Is this on a Saturn or an fbody?
