Battery Terminal Corrosion
Cleaned the tray and base area up only to realize the lip on the tray has cracked. Thinking of getting the year one strap as insurance with the new tray...
Check your f-body battery tray for breakage!!!
***If/when u purchase a new battery tray assy from gm or aftermarket, it does NOT come with a new grommet for the metal overflow tube. I ended up cutting the defective tank in half to get it out from underneath...even then it takes patience.
***gm does not support the grommet # anymore
I was going to try some of the various PCV, and or dipstick tube grommets out there as a replacement when i get around to changing out the tank.
