Sponsored by: CARiD
need a new radiator?
Old Apr 29, 2014 | 08:12 AM
1997transamws6's Avatar
Default need a new radiator?
a couple of weaks ago i notice i was leaking fluid around the cap, so i went a bought a new cap. it is still doing it but not as bad. it is coming from where the cap tightens on the plastic. do i need to buy a new radiator or can i just buy that plastic piece.
Old Apr 29, 2014 | 04:08 PM
Daniel Richards's Avatar
if the plastic is cracked you need to replace it, fortunately you can go to AdvanceAuto online and order one and likely pick it up in store, and if you add 1 more thing that cost atleast $3.01 use can use the promo code WD18 (expires 5-3-14) to knock 50 bucks off the price and be out the door for 75 bucks plus tax (more if the second item cost more the $3.01).
Old Apr 29, 2014 | 11:21 PM
thanks i will look into that
Old May 1, 2014 | 08:40 AM
LS6427's Avatar
If you can remove the radiator yourself.....usually a radiator shop will replace that entire plastic tank on that side for $30-$40........that's what it cost around here.
