Sick Yukon
don't expect to get good fuel economy with that 'suburban' which also has AWD.
regarding lack of power, all that money and parts you're thinking of throwing at the truck will do nothing if the motor has lost compression from wear (piston rings and valves). the only things i would consider throwing at it are a new MAF sensor especially if it has some kind of cold air intake setup or even a k&n air filter. And two new O2 sensors before the catalytic converters, both of which you can monitor with a hand held scanner to get an idea if they are working properly. and don't overlook a bad torque converter in the transmission that could be robbing power on the highway.
and u mentioned electric fan, if you have a mechanical fan it could simply be a bad fan clutch that's making the fan operate at engine rpm all the time which will certainly rob power and suck down gas.
