In dash volt gauge junk?
Battery, alternator and excitor wire are all brand new and not remaned junk either. Checked all my grounds they are in good shape.
With all that said....thoughts?
Oh and I already did this
Voltage at the battery should be WELL above 12.9v with the engine at idle and a minimal/average accessory load.
The dash gauge should be above 13v at idle under normal or light load. You may see it dip below 13 with a bunch of accessories running at idle. In my experience, the dash gauge always reads lower than voltage observed at the battery.
Lets use some basics
R = E/I
R - Resistance of 1.2 ohms for the wiring
E is the voltage of 12V
I is the current of say 10A in this case
1.2 = 12/10
If your resistance goes up say to 1.5 ohms (Heat soak) your current will go down to 8A to keep the same voltage. or in your case the voltage is pulled a little because you still are trying to use that 10Amps at a higher resistance.
1.5 = 12/8
This kind of stuff is used more for car stereo and cable size to run with big amps but also applies to cars with older wiring.
Please correct me if I missed something.
