Sponsored by: CARiD
Airbag light delete.
Old Aug 21, 2014 | 10:06 PM
Empatho's Avatar
Yeah the resistor is better then cracking the leds because you can always bring it back to stock.
Old Feb 29, 2024 | 09:56 PM
Bruce Pochinski's Avatar
Originally Posted by great421
Difficult?
It's so easy even I can do it!
The "write up" (below) is expanded from my original post:
1. Adjust your steering wheel down, then pull off the trim from around the I/P cluster and remove it (No screws, just spring clips).
2. Remove the screws that hold in the clear cluster cover and then remove it. (Now would be a good time to clean and polish the plastic with a Non-Ammonia based cleaner, as Ammonia causes some plastics to fog over.)
3. Remove the screws that hold in the I/P cluster, and detach the electrical connector from the back of the cluster.
4. Pull out the cluster, and then finally pull the ABS bulb from the rear of the I/P cluster by removing the plastic and copper bulb holder (twist 1/4 of a turn) and removing the actual bulb from the holder.
Reverse order to re-install.
Easy!
Easy NOT. On my 2001 Camaro cluster, the air bag light is soldered into the circuit board. And its like that at least on 97 to 02. That was when they put in the digital odometer .
